    Oct 2007
    25
    Allroad V6 Tdi 180bhp...Which Oil????
    Allroad is due an Oil change in the next 300 miles and was wondering what other owners have been using in the form of Oil.
    Engine Code is "AKE" and according to the manual Oil spec should meet 506.00 and/or 506.01.
    I've been recommende Millers XF longlife 0W-30.
    Anyone have any experience of Millers.
    Incidentally,car has been on Longlife servicing but i intend to revert to fixed servicing but still use Longlife Oil as i tend to do short journeys.
    '02 ALLROAD 2.5 TDI 180 TIPTRONIC
    '53 VW POLO 1.4 TDI SPORT.......62+MPG and now 215000 miles on the clock!!!!
    '98 VW GOLF TDI ESTATE.......gone but not forgotten
    Oct 2007
    25
    Come on guys...
    Some of you must have changed your Oil...
    What have you been using???
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    My engine is an AKE too. Shell Helix diesel grade meets the VW spec for top ups, otherwise whatever Audi use as it has FASH.
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    raresicu76's Avatar
    May 2007
    Quote Originally Posted by djl78 View Post
    I am sorry, i can't copy the pictures
    Engine oil: filling up
    The engine is filled with a high-quality multi-grade oil at the factory: this can be used all year round, except in extremely cold climates.
    Viscosity grades
    Select the viscosity grade of the oil according to the chart.
    A -
    High-lubricity multi-grade oils, specification → Chapter
    B -
    Multi-grade oils, specification → Chapter
    A -
    LongLife high-lubricity multi-grade oils, specification → Chapter
    Note
    The oil does not need changing for brief variations of outside temperature beyond the temperature ranges shown.
    Viscosity grades and oil specifications
    The specifications listed here must appear on the container - either singly or together with other specifications.
    Note
    When topping up it is permissible to mix different types of oil.
    Oil specification for standard service
    Vehicles with petrol engine
    A -
    High-lubricity multi-grade oils, specification -VW 500 00- → Note or high-lubricity multi-grade oils, specification -VW 502 00- → Note
    B -
    Multi-grade oils, specification -VW 501 01- → Note
    Multi-grade oils, specification -API-SF- → Note or -API-SG- → Note
    1)
    The date given after the VW specification must not be earlier than 10/97.
    2)
    The oils are particularly suitable for turbocharged petrol engines.
    3)
    These oils should only be used if the approved engine oils are not available.
    Vehicles with TDI engines
    A -
    Improved lubricity multi-grade oil, specification -VW 500 00- → Note (only in combination with specification -VW 505 00-)
    B -
    Multi-grade oils, specification -VW 505 00- → Note-VW 505 01- → Note
    Multi-grade oil, specification -VW 501 01- → Note (only in combination with specification -VW 505 00-)
    Multi-grade oils, specification API-CD (should only be used for topping up if approved grades are not available)
    4)
    Oil specifications for LongLife Service
    A -
    High-lubricity multi-grade oils, for flexible oil change intervals
    New VW standard (specially developed, resistant to ageing) according to specification:
    -VW 503 00- Petrol engines / turbocharged petrol engines
    -VW 503 01- Petrol engines with code letters ASN
    -VW 503 01- Turbocharged petrol engines from 154 kW (only Audi S3, Audi TT and Audi RS4)
    Vehicles with diesel engine
    A -
    -VW 506 00- Diesel engines (not unit injector)
    -VW 506 01- Diesel engines (unit injector)
