Monster MotorsportEM Tuning
    Apr 2004
    A6 trouble starting
    Having trouble starting 98 A6 Q, especially when it's still warm. No problem when it's a cold morning. Replaced plugs, air cleaner, battery, checked pressures in ignition system. Any ideas out there?
    Sep 2003
    6
    Re: A6 trouble starting
    Which engine, 2.8? Some problems can occur when you just move the car out of the garage and then switch off and try to start a little later. Tends to flood. Not heard of hot start problems though. You could try audiworld.com, this has a much larger members list.
    Apr 2004
    41
    had lots of probs with the coolant temp senders.
