    Apr 2006
    Devon, UK
    14
    Shudder when accelerating under modest load
    Hi Everyone!
    My 1998 2.8Q Tip runs very nicely apart from a problem that has only started since a recent service. When I accelerate under modest load (nothing harsh speeding up when passing in to a 60 zone from a 40 zone for example, when the car is already in a high gear and with a couple of passengers or on an incline) the engine will often hesitate for a second before picking up revs with what might be described as a shudder (one, or sometimes a couple, of very short jolts or jerks). Once past this hesitation everything is normal, and under any other conditions everything is normal as well. Im using my VAG-COM to check for error codes on a weekly basis but so far nothing.
    Just before the last service my car started to exhibit a "Load change jolt when easing off accelerator" problem (this is a service manual description), with the following error codes logged: 17953 - Throttle Valve Controller: Malfunction P1545 - 35-10 - - - Intermittent and 17973 - Throttle Actuator (J338): Lower Stop not Reached P1565 - 35-10 - - - Intermittent. On investigation by my garage (an independent Audi specialist) this turned out to be a hose that had disconnected from the throttle body, and my garage also cleaned the throttle body for good measure. This work fixed that problem, but now I have the new problem and Im wondering if there is a connection.
    Since there are no error codes it looks like I will have to start replacing components, but where to begin without spending a fortune? I guess the throttle body is on the list but is there anything else a bit cheaper - to try first?
    Any help much appreciated!
    Cheers - Graham
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    May not be related but what about transmission fluid change some guys on here have found that helps with auto boxes.
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
    Apr 2006
    Devon, UK
    14
    Thanks Max. I'm pretty sure it isn't transmission. I had the fluid changed last year after a scare that I'm sure is linked to this problem in a roundabout way: I was in tip mode and changed down to second to slow the car on a steep hill and there was a MASSIVE bang! Well, my wife and I thought the tran$mi$$ion had gone for good, although it still seemed to drive okay. Taking no chances we had the car towed to our garage and had the fluid changed.
    All was well until the problem with the throttle body before the last service, and the same happened again! However, the transmission is absolutely fine - mostly smooth as silk. To me it seems like there is some gadgetry that controls all this and occasionally it goes awry.
    Hope this hasn't confuesd the issue - still looking to get the shudder sorted
    Cheers - Graham
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    Graham umm doesn't sound good. hope you get it sorted have you looked at coolant temp sensor and air temp sensor. mine was playing up hesitating and loss of power below 3k. replaced the maf made little difference, also coolant temp later and cleaned the air temp sensor in the manifold now runs perfectly.
    may be worth ten minutes. also cam sensors can cause problems.
    Max
    A6 2.4Se Man
    Bmw 520Ise Auto
