Chris NottEM Tuning
Results 1 to 7 of 7
Thread: A6 hesitation
    Daz
    Sep 2006
    Cornwall
    A6 hesitation
    Hi, 1st post. Owned an A6 1.8T quattro for a couple of days now, lovely car in metallic green (nil leather though!). Took her out for a spin today, and found it to be very hesitant on accelleration, as if it was holding back?? It's still under what warranty the garage gave me but I'd like a few ideas first. Would it be worth popping her on a rolling road? Or is there some thing that is common that would cause this? Cheers for any future help.
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    my 1.8 is the same but its mainly when its cold ie. in the mornings
    200 Horses nice !!!
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    Cool usual things to check
    Variable turbo blades get stuck
    MAF units faulty, Coolant temp sensors,Ait temp sensors seem to be the norm and produce the symptoms your describing when cold.
    Not as often but Idle control valves but this doesn't cause hesitation normally just eratic idle.
    I assume its a maunal car else auto boxes can be a little temperamental
    Check for split pipes to the turbo etc as well.
    Hope these help
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
    Daz
    Sep 2006
    Cornwall
    Thanks for the replies, I'll have a look tomorrow, however, it's going back to the garage on Thurs. See what they say!! Coolant temp indication as been a bit erratic, not all the time just occassionally. Idle is fine and yes it's a manual. No fault codes, just have to wait and see. Cheers again. variable blades??? I thought they were fixed??
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    for some reason temp sensors dont always show on fault codes if its erratic then thats probably the problem. these are prone and an easy if not messy fix.
    your temp should be rock solid 90 mine never budges.
    A6 2.4Se Man
    Bmw 520Ise Auto
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    where is the temp sensor located ?
    200 Horses nice !!!
    Daz
    Sep 2006
    Cornwall
    All sorted, MAF replaced under warranty, goes like a dream now - did smile. Few months and I'm sure I'll be wanting to chip her. cheers for the feedback, much appreciated
