Monster MotorsportChris Nott
Results 1 to 9 of 9
    Dec 2007
    Audi a6 2.8 wont start-please help!
    i posted 3/4 weeks ago regarding an intermitent misfire, and that id changed the plugs, leads and coil unit.. i had a reply stating to check the MAF, i have now cleaned the MAF, but car wouldnt start thus meaning jump start!
    After alot of trying the car eventually started, but wont rev above 1000 rpm.
    when you turn the ignition on before the car starts, there is a noise coming from in between the manifold and bulk head, unsure whether this is normal or not??
    the battery has discharged itself in a 24 hr period??
    any suggestions?? although i may of confused the matter a little?? the car has been off the road for over a month now..
    there is not 1 warning light of any description showing
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    not much help i know but i have some thing similar as a loss of power between 1k and 2.3k rpm however it feels like a misfire. i have checked /changed the maf and collant sensor which have made no difference. i am now looking toward the inlet manifold sensor and n156 valve. yours is essentially the same motor as mine. vag com is reporting nothing and there are no vacuum leeks anywhere. it feels like its on choke all the time.
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
    Dec 2007
    that is exactly how mine started, but has progressively got worse!!! apart from taking it to the audi garage and costing a fortune, i have no other ideas?? very disheartening i must say..... must be the hampshire weather!
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    Cool update may help
    I put the old plugs back in mine and i also cleaned up the Airflow temp sensor and this seems to have got rid og the misfire and hesitation.
    This is situated on the black plastic inlet plenum. its a t30 torx screw and remove i think its either grey or green connector.
    May be worth a try it takes minutes.
    Max
    A6 2.4Se Man
    Bmw 520Ise Auto
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    something that has come up on Elsawin for your car apparently the wiring harness to the fuel tank sender can become damaged on the reaer wheel arch inside the boot. this has a similar affect to what we have experienced and also causes the car not to start.
    As i said this in from audi so may or may not help . worth a look thoughyou have to pull the side panel off in the boot to do it and the mat out.
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
    matt_o121's Avatar
    2.8Q
    Nov 2006
    84
    hey max, got any pictures or how to find this in elsawin please
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    Cool elsa win transaction code311101/3
    Technical solution Transaction No.: 311101/3
    Vehicle breaks down, engine misfires Release date: 06-Nov-2004
    Problem description
    Engine warning lamp / glow warning lamp comes sporadically on when driving. Fuel gauge doesn't work, fuse of fuel pump faulty. Fault entry VAS 5051: 01441, sender for lack of fuel.
    Cause
    Chafing of the cable harness to the tank sender (rear RH wheel arch area) because of missing corrugated pipe in the cable loom.
    Production solution
    Cable loom improved, corrugated pipe with wrapping.
    Service solution
    Repair the cable loom (VAS 1978). Protect the chafed area with a corrugated pipe - Part No. N 907 735.01.
    Accounting instructions
    Avant:
    RO 70 03 19 06 remove and install side trim for boot 110 TU
    RO 97 09 41 56 repair central wiring loom 70 TU
    Saloon with rigid backrest:
    RO 70 39 19 00 remove and install lock carrier cover 30 TU
    RO 70 03 19 50 remove and install side trim for boot 20 TU
    Saloon with folding backrest:
    RO 72 47 19 02 remove and install backrest 70 TU
    RO 70 03 19 53 remove and install side trim for boot 20 TU
    Service number/damage code/manufacturer: 9725/025/...
    A6 2.4Se Man
    Bmw 520Ise Auto
