Badger5EM Tuning
Results 1 to 10 of 10
Thread: Loss of drive
    Feb 2007
    Loss of drive
    Well it Christmas Eve, I went out tonight to collect my kids toys, on my way home I suddenly had alot of steering wheel wobble, followed by a complete loss of drive, engine still running and and car still in drive, I managed to push the car into a car park where I have currently left it, but there is no drive no matter what gear I choose, when I lost the drive it sounded as though something metallic was dragging on the ground from the engine bay area, on looking under the car I could see nothing hanging down, when selecting gears there is a grinding noise but no drive, any help would be greatly appreciated
    Car is a 2002 2.5 TDi
    Tony
    Feb 2007
    Ok I have managed to get the car towed to my house, I removed the drivers front wheel as this is where the grinding noise was coming from, behind the wheel and brake assembly there is a drive shaft/half shaft this is broken.....however as you probably guessed I am no mechanic.....why would this stop the car from having any drive as the car is rear wheel drive, is this likely to cost an arm and a leg..
    Tony
    karl7900's Avatar
    Nov 2006
    1,402
    Hi mate,
    Sorry to hear about this. If its an A6 you drive it will be either front wheel drive or four wheel drive (Quattro). If one of the shafts are broken then you probably would loose drive completley.
    Feb 2007
    Thanks, I never realised it was front wheel drive, I just always assumed it was rear wheel drive....you live and learn.
    Tony
    Feb 2007
    Is drive shaft replacement a big/costly job?
    Tony
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Not a huge job as the drive shaft is removable to replace the inner and outer CV joints. Just problem is why did it fail was it the outer cv joint??? is it hanging of at the wheel end or gearbox end???
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    Feb 2007
    At the wheel end, although have to say there is movement back and forth between wheel end and gearbox end???
    Feb 2007
    Is it feasible that a broken drive shaft can cause a complete lack of drive? Surely there should still be some drive from the other drive shaft and wheel?
    please speak slowly so i'll understand !
    Nov 2007
    north of the border
    160
    yeah its a complete lack of drive as the diff will send the power through the path of least resistance !
    Feb 2007
    Thanks just got to wait for the garages to open and get it booked in to be repaired now hopefully not too costly
