Kinda wish I'd found this site BEFORE I started this job
I'm a NOVICE in the mechanic ranks. The extent of my mechanics extends only to fitting car stereos, replacing bulbs/fuses, and removing and refitting "trim". Anything under the bonnet is usually a big "no-no" for me - that's what my mate's for
However, last night I managed to remove the wiper linkage. Passenger side seized up.
My initial help came from a Haynes manual (so yes, I did RTFM!) and the following link:
http://pictureposter.audiworld.com/showthread.php?t=2383247
To get the plastic airflow/grill off, there are just 3 metal clasps (left, right n middle). The middle one was the most difficult to budge (due to access), but once off the grill/cowl just pulls out. You may need to use a little force, but it does (or should!) come off fairly easily.
BTW, the Haynes tells you to prize off the splines from the ball joint whilst the linkage is still fitted into the car. Well unless you are a seasoned mechanic, I wouldn't bother with it. I managed to get the entire linkage (plus motor!) out with just a wiggling, sliding motion and some perseverance. I did cut my hands and fingers to shreds in the process, so perhaps a little care should have been thrown in.
At this stage, my linkage is still removed from the car and is now sheared at one end thanks to me taking the BFH approach to the seized spindle. I had tried WD40 and a 3-in-1 penetrative loosening spray, and I even soaked it in paraffin overnight and tried again with the 3-in-1 and WD40 this morning. Nothing seemed to shift it. It was completely seized up! On the plus-side, I tested my wiper motor with no linkage attached and it still works
Thought I'd just add my few pointers/tips (bear in mind, RH-drive):
Driver side bolt holding the linkage in place was probably one of the more difficult bolts to undo due to restricted access. Too short and the ratchet hits the windscreen, too long an extender and it hits the bonnet. Probably a lot easier if you have a snaked/flexible extender. I just used patience
The wiper motor is held on by 3 screws. These are MUCH easier to undo after you unbolt the linkage from the bodywork, and then tilt the whole assembly towards you (or towards the front of the car).
There is (or was, in my case!) a rubber washer/grommet on the top of the motor spindle, which I managed to lose when removing the bracket that holds the motor to the linkage, so beware.
Right, I just need to find a spare wiper linkage from somewhere now :/ and then I have the absolute AR$E of a job of re-fitting it all. I may just give my mate a call ;-)
Pete
