Volks AutosBadger5
    gav
    gav's Avatar
    S6 vvv
    Apr 2007
    AYRSHIRE
    21
    s6 wheel fitment
    can anyone tell me if the wheels of a 2006 rs4 19 inch pcd 112 ,offset 29mm will fit my s6 2001.
    any help would be much appreciated, thanks
    Nov 2004
    Kent, UK
    138
    Gav,
    I'm not sure what the et is of the S6 to be able to tell you whether the RS4 wheels will fit. The easiest way is for you to take a look at one of your current wheels. It should be stated either on the wheel underneath the centre cap or on the back of one of the spokes.
    The pcd on your car is 5x112, it's just whether the et 29 of the rs4 wheel will make it stick out too far.
    John
    B5 S4 avant - for sale!
    Allroad 2.7T
    Jan 2007
    ayrshire
    20
    I think it will be fairly tight standard s6 wheels are 8x17 et35 and the optional 18s are 8.5x18 et30 and they fill the arches well rs6 wheels are 9x19 et35. The old rs4 wheels are 8.5x18 et20 and they dont fit the s6 I tried a set on mine they are too far out. I dont know what width the new rs4 wheels are but at et29 if there are 9 inch they might be too far out 6mm further out than an rs6 wheel.
    http://www.1010tires.com/WheelOffsetCalculator.asp
    This is usefull for working offsets out.
    David
    gav
    gav's Avatar
    S6 vvv
    Apr 2007
    AYRSHIRE
    21
    Thanks for your help, dont think ill bother then, pity tho cose the wheels where smashin.
