Sky InsuranceAH Fabrications
    Sep 2007
    help!!! loosing coolant
    Hello everybody!
    I'm new on this forum and i have a problem with the coolant. I don't know from where i'm loosin it. I looked under the car and it's dry, i've replaced the coolant tank but still i have to refill the tank once a day because the level drops below min. Does anybody know the solution to my problem, a friend of mine said that it might be the tank's cap, and it looses water vapors
    thank you
    The car is an audi a6 avant 2.5tdi 2003
    audi a6 2.4tdi 163hp
    bmw 540i 286hp
    chopper602's Avatar
    3rd + overdrive
    Dec 2006
    Middlesbrough - Teesside
    Have you checked the oil? Is there water in it? Have you noticed steam in the exhaust? Could be head gasket . . . .
    Tim
    Teesside
    2008 Mazda MX5 2.0 Sport
    2006 Audi A6 TDi S-line
    1985 Citroen 2CV6 Special
    Sep 2007
    I have checked the oil, the exhaust is clear without any smoke. Well it seems that after I changed the coolant tank the whater level dropped becouse all the air has gone out and now the level remained constant after a few trips. I belive the problem is now solwed, thanks for help
    bmw 540i 286hp
