Results 1 to 8 of 8
    Dec 2005
    london
    196
    can newer steering wheels fit on 1999 A6?
    I want to replace the standard 4 spoke wheel for a 3 spoke but do the newer a6 style ones (late 2001 onwards) or other audi car wheels fit my 1999 a6?
    If not I will just go for the sline quatro one like this..... http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=001
    but would prefer the ones with the chrome ring in the middle similar to this one..... http://cgi.ebay.de/Audi-3-Speichen-S...QQcmdZViewItem
    does anyone know what goes on ok?
    cheers
    Dec 2005
    london
    196
    anyone?
    TonyT's Avatar
    Finally got my A6
    Jul 2006
    Central Scotland
    85
    my concern would be more to do with compatible air bags. not sure if the all have the same plug on the end.
    TonyT
    2001 A6 Avant 1.8t, she's a little beauty.
    Never drive faster than your gaurdian angel can fly.
    It's just a "common problem"
    Jun 2007
    Quote Originally Posted by TonyT
    TonyT
    A6 avant? little beauty? Little?!?!?!? is a flippin bus is what it is. Nice bus though. Got one myself
    Mar 2007
    Right, the more important thing is airbag compatibility between single stage airbags and dual stage airbags.
    Generally, the wheels will bolt over, it's just making sure the electronics all work correctly. I'm in the middle of a retrofit and trying to figure out how to make the tiptronics work...
    Sep 2007
    15
    isn't there write up on retrofitting somewhere?
    I saw it once.
    found the link for ya
    http://www.audiworld.com/tech/int38.shtml
    Mar 2007
    The problem I have is I have an S6 with the multifunction steering wheel (MFSW) that uses a CAN-BUS controller. Basically, all the buttons the wheels (volume, station search, phone, etc.) all pass through two wires. The standard tiptronic wheels do not appear to use CAN-BUS and are hardwired to the TCU. So, I'm figuring out exactly what I want to do. I may ultimately end up tapping the center console, like in the write-up, but I'm trying to see if there are other options...
    Thanks though.
    Sep 2007
    15
    ah...... if you ever able to figure that out. would like to know how you did it. that will be interesting. I thought about putting steering after I read that link mysqlf but your project is more interesting.
