Volks AutosMonster Motorsport
    shabazmo
    engine stall, 2.5tdi multitronic
    My audi 2.5tdi 101K miles has today developed a stalling problem. when the engine is idling, the car will stall after a few seconds. It happens about 30% of the time and occurs in any gear, N, D, P, or R. I filled up with fuel earlier today from Q8 and am beginning to wonder whether it is bad fuel. The car runs normally and doesn't seem to lose any power but the fuel consumption reading appears to have increased.
    Has anyone any ideas.
    Regards
    shabazmo
    I have now been able to put VAf COM on the car and it shows 2 faults.
    00575 - Intake manifold pressure 08-10 - control limit surpassed - intermitent
    17583 - pre injection turned off P1175 - 35-10 intermitent. Does anyone know what needs replacing
    meatychi's Avatar
    Jan 2005
    UK
    260
    You may find that you need your Crankcase breather filter replacing!
    I used to display the same intake manifold pressure fault and then plumes of white smoke started bellowing from my exhausts, when pulling up to a junction.
    After replacing this filter the car runs a lot smoother.
    1998 A6 Avant 2.5tdi Quattro Tiptronic Sport
    shabazmo
    Thanks for the information. Yestareday the car staled and would not start. White smoke did come from the exhaust and when I put vagcom on it again it found another fault.
    My Audi 2.5tdi 101K miles has today developed a stalling problem. When the engine is idling, the car will stall after a few seconds. It happens about 30% of the time and occurs in any gear, N, D, P, or R.
    I have now been able to put VAG COM on the car and it shows 2 faults.
    The following day, the car started and then won’t start. Following fault was found. 01126 Engine speed signal
    16-10 Signal outside specification – Intermittent
    Fault codes cleared but the engine still doesn’t start.
    Can you tell me where the crankcase breather filter is.
    Regards
    meatychi's Avatar
    Jan 2005
    UK
    260
    Sorry not much help on that front as I didnt replace mine.
    According to my mechanic, the turbo had to be removed.
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    Go to this thread called '00 2.5tdi clouds of white smoke!!! ( 1 2) in the diesel forum
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
