Chris NottAH Fabrications
    Dec 2005
    england
    12
    Control module for injection pump
    Hi
    My 99 a6 2.5 tdi cut out yesterday. managed to get it towed home ok.Called a mobile diagnostic mechanic out and it said the control module for injection pump has packed up.
    Audi says you have to buy an exchange injection pump+ control unit for 1500 +vat
    Found complete pump and unit in the brakers for 400 +vat
    What I need to know is can I just replace the contol module which is bolted on top of the injection pump which is a 5 min job or will I have to replace the whole pump unit ?
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Got this from elsawin
    For security reasons, in all vehicles as from the 2002 model year the injection pump is integrated in the immobiliser system.
    t When an injection pump has been renewed, it must be re-adapted to the immobiliser (same adaption as when replacing the engine control unit), otherwise the engine will not start.
    In theory a second hand pump should work but the pump has to be timed to the engine. If you pm me with an email i can send you the procedure, but it looks like a replacment pump comes preadjusted to match the timing setting on the engine. Anyway I'll send to you and you can see what you think
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    Dec 2005
    england
    12
    p.m sent to Enda1
