EM TuningBadger5
Results 1 to 7 of 7
    Mine a manual
    Sep 2006
    29
    Xenon adjustment for france
    Hi,
    Mine=2001 Allroad with Xenons.
    Can sombebody tell me whether I have to have the pattern adjusted for contiental europe? halford/main dealers seam really vague.
    thanks
    Adam
    matt_o121's Avatar
    2.8Q
    Nov 2006
    84
    i am not sure about xenon's but the normal headlights have a lever next to the rear of the dip beam unit which you have to just move to the side to change the beam cut off for continental use.
    it is outlined in the owners handbook,it should be the same for xenon units
    Mine a manual
    Sep 2006
    29
    Well you'd think so... the manual says that adjustment should be made by main dealer due to high voltages, but the dealer says adjustment isn't necessary. They're so bright I don't want to upset oncomming lorry drivers late at night on the way down.
    thanks
    Adam
    Jan 2007
    Laaaaandan
    263
    @Adam, did you ever get an answer on this? I have the same query for my A4 Xenons, wonder what I do if I hop over the channel...
    Jan 2007
    ayrshire
    20
    Hi the xenons have a lever the same as normal lights I did the lights on my s6 before a trip to switzerland last year. One lever is easy to get at the other one is a bit harder it took me 10 minutes in total with lights turned off so no high voltages.
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Any idea on wether this lever exists on the 2011 A6 C6 (last of the C6's)?
    LostBok/BahnStormer77
    May 2006
    UK
    167
    on the C6 its a dealer job and it will cost lots!! I have just come back from trip to Austria and I did not bother. That is my advice as it really makes no difference. If you really want to you can buy stickers at the tunnel which stick on the front even for Xenons.
    3.0 TDI S Line Quattro Avant, Leather, Bose, Colour MMI Sat Nav, Phone, LED rear + Xenons
