EM TuningVolks Autos
Results 1 to 11 of 11
    Nov 2006
    02 A6 drivers door handle
    Drivers door handle on my A6 seems not to be operating the latch mechanism correctly - sometimes the latch doesn't operate until you pull the handle all the way to it's stop, sometimes it seems ok . . . the inner door handle works normally all the time, is this a common issue . . . before I pull the trim off the door and see what's wrong . . . ?
    Fd
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    Never seen it before and Ive had 3 A6's now.
    Its an easy job to wip off the interior door card and see whats going on.
    Once you have it off also check to see the condition of the window carriers.
    If they look as if they are split change them whilst you are there.
    The carriers are plastic oblong things, about 4cm x 3cm which the stud on the steel cable sits in. One either side.
    They tend to crack or break and you get uneven window closing, or the window goes up and then down again on its own
    Simon
    A6 3.0TDI Quattro Avant Le Mans
    A6 2.5tdi Quattro Sport 180 Sadly Missed
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    SatNav, BT, AMI, DAB
    Jul 2007
    got the same problem on my a6 found if you push the door in then the handle works ok
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    i've got the same problem seems worse in hot weather, but i'm not too worried over the winter the handles are going!
    To be replaced by Electric poppers.
    Mar 2007
    6
    Did you get the handle issue fixed ?
    Got the same problem !
    Dec 2004
    Bristol
    449
    Yes it was a new lock/latch mechanism, got one from a breaker as my car's a high miler so alot of use on drivers door.
    Now fixed for about 15
    Try ebay or online breakers.
    Mar 2009
    24
    Hi people.
    I'm getting exactly the same problem here. You say replacing the lock mechanism fixes it. What is the lock mechanism and which part of the door is it? How do I take it apart, is it just screwed in etc...?
    Sorry, I am a complete novice, if someone can explain in detail I would be most grateful.
    Dec 2004
    Bristol
    449
    It's the lock latch mechanism, bolts in the door with 3 torx bits, u need to remove the door card. not too bader job, bit fiddly, take an hour or so.
    Mar 2009
    24
    Mar 2009
    24
    Cheers mate. Is there any parts shop you can recommend? I dont want to go to Audi to get it. I dont know where I can get car bits from other than the main dealers (Im not stupid just a complete car repairing novice). I know some go to breakers but Id rather buy new.
    I went to Audi yesterday as I could not open the door initially. The techy looked at it, shook his head and said I will need to saw it out mate. Its an MOT failure as well if you cant open the door. Ill probably end up scratching the paint work as well. As you can imagine the confidence I got from this.
    I told someone I know about it and he said Push the door in before lifting the handle, then lift the handle. Guess what, the door opened. Since greasing the lock latch I can open the door fine from inside the car but I still have to push the door towards the car before lifting the handle to open the door from the outside.
    Does this mean I still need a new lock latch or is there something I can adjust to make the outside door handle work better?
    Audi also quoted me 400 for an auto gearbox oil change. Getting done for 90 at an independent. Main dealers are a joke.
    Dec 2004
    Bristol
    449
    You will still need a new latch mechanism, thats what i changed, been fine ever since.
    I used online breakers (cos i'm a student and stealer parts prices are a joke!), do a search on google, enter car details etc and wait for the quotes to roll in.
    Also try ebay for A6's breaking and email them asking for the part, go for a low mileage one, but i got mine without knowing the lileage for 35 it does the job.
