Sky InsuranceBadger5
Results 1 to 8 of 8
Thread: et??????
    Nov 2006
    21
    et??????
    will wheels that are 7.5j with ET30 fit straight on to an A6 Avant
    cheers
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    They'll stick out 8mm more than standard wheel but that won't be a problem with that width wheel. The pcd is more important.
    Built in Germany, Perfected in England
    Nov 2006
    21
    What is PCD I never did know also 2 have 215 tyres and 2 have 205 which is better
    Les 51's Avatar
    A pint of Diesel please!
    Feb 2007
    Cambridge
    687
    pitch circle diameter. It's the measurement between 2 holes across the centre of a circle
    LISTEN TO THE Bluehorses THEY ROCK!
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Basically the distance between each stud hole on the wheel. Needs to be 5x112 or 5 studs each 112mm apart. 215 tyres would be best. What size are the wheels?
    Nov 2006
    21
    they are 5x112 didnt know it as pcd just stud pattern, they are 17x7.5 et30
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Yup that's fine mate. Go with the 215's
    Nov 2006
    21
    Cheers mate
