Removing and installing rear light
Removing
Switch off ignition and remove ignition key.
Turn light switch to 0 position.
Remove luggage compartment side trim cover.
Unplug electrical connector.
Unscrew the 4 nuts.
Squeeze retainer tabs -arrows- at bulb housing -2- and detach rear light outwards.
Installing
Install in reverse order, paying attention to the following:
NoteMake sure gasket between body and rear light housing provides a proper seal.
Before tightening nuts, align rear light with body contours (even shut lines).
Tightening torque
Rear light to body 4 Nm
