Volks AutosSky Insurance
Results 1 to 11 of 11
    Jun 2007
    Exclamation Heavy Steering and Battary warning light on ___ Help
    Hi all,
    I have a serious problem i think. I have an A6 1999 Limousine 2.5 TDI V6 , Suddenly my Battery warning light has come on and the power steering is really heavy. What is the problem
    please help
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Sounds like the auxilliary belt has come adrift because it powers the alternator (the battery light) and the power steering pump (the heavy steering)
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Jun 2007
    Thanks, Do you have any idea how expensive it would be to repair, and iwould it be safe to drive to a dealer???
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    happened on my old 2.8q.
    Its possible to drive but very hard work. The only thing is the battery wont be charging, so possibly, it could drain the battery low enough to not be able to power the ecu etc and you will stop.
    parts wise its very cheap, its just labour to get to it. should only be a couple of hours work though
    Simon
    A6 3.0TDI Quattro Avant Le Mans
    A6 2.5tdi Quattro Sport 180 Sadly Missed
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    SatNav, BT, AMI, DAB
    Jun 2007
    thanks
    I will drive to Garage in morning. its only 10Km away
    Nov 2006
    10
    Sounds like definaltely the alternator (or belt)
    Mine went in December whilst abroad and cost around 700 Euro to fix
    Alternator was 400 & labour 300 (At an Audi dealership)
    I have the 2.7T so yours may be less expensive
    I will not be driving the car too far though as you dont want the battery to drain and risk other electrical issues
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    You could always have a go yourself if you have a basic engineering knowledge. The drive belt isn't as tricky as a cam belt.
    If it's only slipping on the pulleys then you might even get away with just retensioning it, but it depends on how damaged the belt is from the slipping.
    Jun 2007
    Well its in the dealership now
    I will tell you all what the dealership said and quoted, as soon as I know..
    Jun 2007
    OUCH 1550
    okay car is back, Bel;t snapped and then managed to snap the Idler, This then caused more damage.
    in all though the cost with labour came to 1550 Euro
    Thanks to all who replied and tried to help me
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    That seems rather expensive!
    Chris
    See my images @
    Aug 2005
    staffs uk
    351
    I think you've been taken for a ride there.
    If all they have done is changed the auxiliary belt it should only be a couple of hours work.
    I know on my V6, its front bumper off and pulll forward the radiator etc, but I now how long its takes as I helped my mate change the water pump a couple of weeks ago.
    Even a stealer rates it wshould have been no more than 3-400
    Simon
