Badger5Monster Motorsport
Results 1 to 9 of 9
    Nov 2006
    A6 2.5 TDI '02 Manual - Gearboxes
    Are the 6 speed manual boxes on these cars generally reliable ?
    My car has an increasing speed related drone and I can't find any wheel bearing that is obviously noisy . . . concerned it may be a final drive/diff bearing failure.
    Gearbox function is as it always has been not the slickest on the planet but no change.
    Does the motor have to come out to take the 'box out ?
    Fd
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    changing gearbox is not a 5 minute job on these. Are you sure the droning noise is mechanical based.
    Could it be tyres?
    Is the droning constant or just at certain speeds etc
    Simon
    A6 3.0TDI Quattro Avant Le Mans
    A6 2.5tdi Quattro Sport 180 Sadly Missed
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    SatNav, BT, AMI, DAB
    Nov 2006
    Tyres ?
    Eh . . . No . . .
    The noise is road speed related and may (I hope) be starting to sound worse when cornering one way (I hope - because that's probably a wheel bearing).
    Whether removing the 'box is a 5 minute or 5 day job is not really relevant, if it's fscked it'll need to come out and there's no way it's going into a dealers where some untrained, uninterested yob will do a bad job and charge me a fortune for the pleasure . . . ain't ever going to happen ;-)
    Fd
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    My '51 plate gearbox is still good at 176000 miles
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Nov 2006
    Thanks for that, I'm planning on taking this one to 250K like my old '100 . . . we'll find out tomorrow morning when it all comes to bits . . . I've optomistically bought a wheel bearing kit . . . I hope I need it ;-)
    Fd
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    I had the box changed on my 1.9Tdi i know it's not the same but the job is easier than most transverse mounted engines like fords vauxhalls etc so the job it'self is not too complicated and plenty of space to work with.
    Nov 2006
    Just a quick follow up, despite there being absolutely no symptoms with the weight of the car off the wheels the offside front wheel bearing was well gone . . .
    the bearing fell to bits once removed from the car and I started trying to press the hub out . . .
    While I'm at it . . . manual transmission oil . . . I assume like most modern cars the gearbox oil is sealed for life, but an ex VAG guy I know mentioned a spec change to the box oil - presume folk just buy from Audi . . . if not - what are people using if they change ?
    Fd
    Nov 2004
    Kent, UK
    138
    Fd,
    I would definately check with the dealer on what spec they suggest, especially if you suspect an update to what the manual states. I always find the parts guys are the most knowledgeable and willing to help in my local dealership.
    Cheers,
    John
    B5 S4 avant - for sale!
    Allroad 2.7T
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    As for oil i know in the states it seems more pertinent to change gearbox oil even the for life stuff. though i know thats not the thinking here. some owners are replacing at up to every 6000miles for gearbox and 3000 for engine.
    A bt overkill i know.
    Max
    A6 2.4Se Man
    Bmw 520Ise Auto
