Badger5Chris Nott
Results 1 to 8 of 8
Thread: Where On Earth?
    Mar 2006
    Norwich, Norfolk
    56
    Where On Earth?
    Hi guys,
    bought some aftermarket LED rear lights for my 2000 Audi S6 about 6 months ago.. recently I started getting a bulb warning light come up on the dash when I applied the brakes. Started off as intermittent but now more or less all the time.
    What I have discovered is that with the engine running when I apply the brakes one of the brake lights comes on and then goes off, causing the alarm.
    One side is perfectly fin however and stays on.
    Upon further investigation this is the outcome
    No Ignition Engine off / all fine
    Ignitiion on, engine off / all fine
    Engine running / light fails intermittantly
    sidelights or headlights on / all fine
    Someone has suggest that due to the less power required by LED's that this boils down to an earthing problem. am I right in thinking that as its when the engine is running it could be engine earth?
    If so can someone tell me where I might find the engine earth, or indeed any of the earths so I can check that they are all ok.
    As a side thing the same side (N/S) passsengers lights failed around the same time, so when I open the soor the lights no longer come on, nor do the interior lights with the door opening.
    Sorry for the long winded explanation, any help or thoughts or similar experiences would be appreciated.
    W.
    AJO
    Sep 2006
    135
    Quote Originally Posted by claytow
    because they draw less power it makes the system think a bulb is blown....
    do you have any pictures of these lights mate?
    Mar 2006
    Norwich, Norfolk
    56
    I do, but you can see them on ebay if you do a search for Audi S6, they come from Germany, and its only the stop and tail that are LED the indicator and reverse are still bulb. They are cool and very bright compared to standard bulbs. btw if i put the standards back no problems at all. I have had the lights imdependently checked off the car and they both work fine. Let me know if you cant find them and ill upload a picture.. not on a good connection at the mo so would take ages
    W.
    AJO
    Sep 2006
    135
    ive seen the pics on ebay mate... just shows them close up and not lit up!
    id like to see what they look like on the car as a whole... and also lit up
    your problem sounds very confusing to me... specially as standard lights are fine and so are the LED ones off the car
    Mar 2006
    Norwich, Norfolk
    56
    Ok mate will get some pics uploaded for you.
    Any other thoughts welcome... I think my first thing is to check all the earths if anyone can enlighten me.
    Mar 2006
    Norwich, Norfolk
    56
    Have some Pics But how do I upload them here?
    Guess noone else can tell me where my earths are?
    Mar 2006
    Norwich, Norfolk
    56
    They are in the gallery under A6 as there is no S6 section hope they are ok.. sorry the car is soo dirty but it has just rained here
    enda1's Avatar
    Jan 2006
    Ireland
    439
    As AJO said the led's use less power so the DIS doesn't detect enough current going to the bulbs and thinks a bulb has blown. Have seen in other threads people suggest wiring a resistor into the circuit to bring the total resistance to be the same as the resistance of the old bulbs then the DIS system should work fine.
    Don't know about the intermittent failure though
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
