JMB RetrofitsVolks Autos
    Mar 2007
    DORSET
    112
    A6 1998 SAT NAV RETRO FIT
    HI ! Can anyone help ??
    I have a 1998 2.8 quattro A6 avant , I would like to retro fit an AUDI SATNAV in the centre console ...
    at present i have the AUDI concert stereo above the dual climate control and a 6 disc auto changer (in the boot) ,
    is this an easy task , ............or is it not worth the hassle ???
    matt_o121's Avatar
    2.8Q
    Nov 2006
    84
    i have recently fitted an rns-d unit in to my 97 2.8Q, it is quite a big job and also not cheap.
    you will need to get:
    a double din radio cage,
    a double din climate control,
    double din ash tray,
    and the unit- the parts other than the radio are quite expensive and it would be worth splashing the cash to get all of the parts together,
    try ebay.de and search for 'a6 doppel din' you will find sellers listing all the parts together.
    Mar 2007
    DORSET
    112
    hi , thanks for the reply , off to check ebay.de,
    thanks for the advice , any idea about totaL COST ?
    CHEERS
    matt_o121's Avatar
    2.8Q
    Nov 2006
    84
    i would say you would be looking to spend 400-500 including the nav plus unit.
    there are bargains out there, i got my nav plus brand new for 200. from an audi dealer on ebay.
    its worth getting all the costs before you start,
    try to find the double din radio cage used, they are on vag parts, but are nearly 200.
    it is nice though.
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    You may also find you need a Canbus emulator as well. If so this will set you back about 100-120 euros.
    Simon
    A6 3.0TDI Quattro Avant Le Mans
    A6 2.5tdi Quattro Sport 180 Sadly Missed
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    SatNav, BT, AMI, DAB
    Mar 2007
    38
    a6 sat nav
    personally I would not bother with Audi Sat nav. I had it factory fitted in my A6 and frankly Tom Tom is better! The only benefit is that you do not have to take it out of the car to avoid it being stolen. Functionwise it is poor, doesn't take full post codes and the latest update disk (2006) still thinks the A1 goes past ferrybridge power station to the east, even though the new road has been there for years.
    really not worth the money even if you can do it!
