Volks AutosChris Nott
Results 1 to 14 of 14
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    strange whirring noise coming from drivers side front wheel
    i got a strange noise coming from the drivers side front wheel as if something is catching at first i thought it might be the mudflap but on closer inspection theres nothing in the way that i can see the noise is intermittent and only does it in a straight line and it also does it with the car in neutral and its gliding
    200 Horses nice !!!
    Mar 2007
    Could be a Wheel Bearing?
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Wheel bearing, CV joint or severely worn brake pads.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    the brake pads are new, i checked the cv joints they look ok could be wheel bearing i spose ill check that
    200 Horses nice !!!
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Wheel bearing jack up and check for play
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    Failing cv joint tends to make the most noise on full lock, bit like a bolt rolling around in a tupperware box
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    Not sure about the A6 but some cars have a plastic or thin metal shield round the brakes and I have known these to be damaged and bent slightly in the past. During cornering the movement in the suspension components stopped it catching but in a straight line it was rubbing and causing a noise.
    Like I say I'm not sure if the A6 has something like that but may be worth a look in case it is bent or damaged at all.
    2004 1.9TDi A4 Avant Sport, GmbH bodykit, DPM Remap, Fishscale Alu trim, RNS-E
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    everything looks ok however ive only had the noise since it went thru its mot so maybe the mot guy wiggled something loose i dunno it sailed thru the mot as well
    200 Horses nice !!!
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    If its something rubbing you should be able to see where as it will be clean I guess. Sounds to me it may just be ever so slightly bent, maybe done when the car was being checked over.
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    another reason i said it might be something rubbing is because there looks like there tiny marks on the inner tyre tread
    200 Horses nice !!!
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    Nothing should be rubbing anywhere near the tyre in a straight line. Its bad enough if something is catching a brake disc or a wheel but I'd be pretty concerned if I suspected something rubbing on the rubber..!!
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    i am concerned but its not happening all the time i mean since i started this thread its not happened once (touch wood)
    200 Horses nice !!!
    Jan 2007
    16
    a stone trapped between the brake disk and the backing shield?
    Caliper (are they floating) sticking, so one pad rubs on the disk?
    Allroad 2.5tdi 2001
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    as i say everything looks ok
    200 Horses nice !!!
