Volks AutosChris Nott
    Mar 2007
    New member (Hi!) and a problem:(
    Hi everyone
    i wonder if you can shed some light on this, My 1996 Audi A6 2.5 TDI auto, it acts up sometimes, car sometimes is juddery when going and yesterday the glow plug light was flashing when i was going along. What does this mean? i checked my owners manual but nothing about it.
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    sorry cant help ya as i aint got a diesel but welcome to the site
    200 Horses nice !!!
    L1 HCS's Avatar
    Candy Tetris Champion, Mahjong Champion, Magic Ball Champion
    Oct 2006
    cymru
    4,597
    Hello & to the site.
    "Swallow your pride occasionally, it's not fattening." - Frank Tyger
    "Avoid making irrevocable decisions while tired or hungry." - Robert Heinlein
    Mar 2007
    Thanks for the warm welcome
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    Check the MAF as it is generally the first point of problem. iwould suspect the ECU may be at fault as well hence the glow plug light. Best bet is find some one close to you with vagcom and check it. there seems to be a number of people on the site with it and are up north so you should not need to look far.
    Sorry not to much help.
    Welcome any way
    A6 2.4Se Man
    Bmw 520Ise Auto
    matt_o121's Avatar
    2.8Q
    Nov 2006
    84
    the coil light also works as an engine management warning light if it is flashing when you are driving along it is indicating a fault.
    the general fault when this happens is a fault with the brake light switch.
    get someone to check the operation of your brake lights as a starting point.
    the bake light switch has two curcuits one operates the lights the second tells the engine ecu you are braking.
    if the two curcuits are not working together it indicates in the form of the flashing coil light.
    it MAY also give you a small running fault in that the ecu retards the engine when you are braking.
    worth a try for the price they are.
    matt
