Volks AutosChris Nott
Thread: MAF Location
    meatychi's Avatar
    Jan 2005
    UK
    260
    MAF Location
    Morning All!
    Can someone tell me where my MAF is located. I wanna try disconnecting it to monitor performance.
    I have a 1998 V6!
    1998 A6 Avant 2.5tdi Quattro Tiptronic Sport
    TonyT's Avatar
    Finally got my A6
    Jul 2006
    Central Scotland
    85
    on my 1.8t it is in the airbox. open it as if you were changing the filter and have a look
    yours might be different.
    if you just want to disconnect it ( and its in the same place as mine) you should find a bubber sealing grommet going into the top of the box. gently lift this back and your maf is directly below. it is possible to disconnect with out opening box.
    hope this helps
    TonyT
    2001 A6 Avant 1.8t, she's a little beauty.
    Never drive faster than your gaurdian angel can fly.
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    The Mass Air Flow sensor of the V6 is in the pipe from the airbox. It is very easy to see and disconnect. There is a length of flexy hose that runs from the MAF sensor unit that leads the the back of the engine and the throttle valve.
    Disconnecting it may not do much. I tried starting the engine without the MAF sensor in place and it just shut the engine down as it assumed there was no air intake. But I'm not sure how the ECU would interpret a loss of signal from the unit so give it a try.
    Hope this helps
    Jason's Avatar
    Mar 2005
    France
    186
    When the MAF was knacked on the wifes Beetle disconecting did'nt make a difference neither did cleaning it but once changed performance was mental,I used to clean the maf on my v6tdi every year or so and it made a world of difference and never had to change it.
