Sky InsuranceChris Nott
    AJO
    Sep 2006
    135
    How to Bypass the Audi Amp to rear speakers
    The adapter you need for the rear amped audi system is the PC9-401
    Standard System
    The standard concert headunit runs only the front speakers, the rear speakers are amped up and so is the sub. they run at the following powers:
    Front 2 x 15W straight of the head unit
    Rear 2 x 25W off the amp in the rear
    Sub 1 x 80W off the amp in the rear
    by upgrading the head unit (probably 4 x 50W) you have had the following effect:
    Front 2 x 50W straight off the head unit
    Rear 2 x 50W which then runs to the Audi amp and reduced to 2 x 25W
    The factory amp is lowering the signal to the speakers which is where the well known interference comes from.
    What you need to do
    1/ remove the plastic inner sills that run down the length of the car
    2/ remove the lower part of the back bench so you can pull the carpet up
    3/ pull the carpet back to reveal the wiring looms near both rear doors
    4/ Find the loom thats got two wires taped up (its held down with duct tape)
    5/ unplug the Audi amp in the boot and turn your stereo off.
    6/ Cut these two wires to each door.
    7/ run new speaker wires from the rear outputs on the headunit along the sills
    8/ connect the new wires into the wires you have just cut coming out of the doors
    9/ tape up the old wires coming from the Audi amp
    10/ plug in the audi amp that now just runs the sub
    11/ replace all the trim/carept and seats
    12/ enjoy your stereo that now runs at 4 x 50W with an 80W sub.
    Feb 2011
    would this work on audi a3 3 door thanx
    Sep 2012
    23
    Quote Originally Posted by robefc View Post
    I have this same problem to is their a easier fix for this I got the PC9-401 still only get reduced sound from the back speakers the only speakers that have running at full 50W are front 2.
    Sep 2012
    23
    I have the same problem to did anyone do this mod and did it work
    And did it work.
