Sky InsuranceAH Fabrications
    Jun 2004
    Callander
    91
    Allroad - Suspension Settings
    Just picked up my new(old 2002) Allroad today - great to be back in an A6 after several years spent out of one.
    Just been reading through the owners manual trying to findout how I place the suspension in Automatic mode. Can work out how to manually adjust the height (indeed driving back from the garage it was in LOW all the way).
    Any help appreciated.
    2002 Allroad Tdi TIP Quattro, Merlin Purple + Recaro + HID4U Conversion
    Jan 2007
    Lancashire
    7
    Press EITHER the up or down button and hold until the yellow 'manual' neon goes out.
    2001 A6 Allroad 2.5tdi Tip Highland Green
    Jun 2004
    Callander
    91
    waddecar
    Thanks, although the only Yellow Lamp I have is for the highest position.
    I remember reading somewhere that there where some changes made to the configuration of the suspension software.
    I can manually select any of the height positions by pressing the Up or Down button, the green LED of the setting I've selected flashes until it is reached. Doesn't seem to be any of the speed dependent changes?
    Feb 2007
    2001 and 2002 models are different. I have an early 2002 that is actually a 2001 model. Yours from your description is a 'proper' 2002 so probably waddecar nor myself can offer much help...
    HTH
    C
