Badger5EM Tuning
Results 1 to 15 of 15
Thread: 2.8 V6 Engine
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    2.8 V6 Engine
    Just a quick thread, can someone tell me what the idle speed for a healthy 2.8 V6 should be?
    Mine keeps trying to drop down to about 400rpm and just wondering if it's that which is causing stalling and whether it needs resetting. If that's about right then I need a new throttle valve.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    ISV will need cleaning or replaced ISV =Idle stablization valve which controls the the idle speed
    If you go on to www.audiworld.com click on resources-tech info-engine should info regarding cleaning ISV
    cheers
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    just checked and guy has done write up under ICV a little confused he is but good pics and detail
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    Had a quick look at the article for cleaning the ICV, haven't had a chance to compare it to mine. Do you reckon it's exactly same layout for a 30v? As the article refers to a 12v.
    I've looked on ElsaWin workshop manual and they say to clean/replace the throttle valve. I assume they're referring to the same item.
    But out of curiosity, what should the stabilised engine idle speed be? Anyone?
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    800rpm i would say......should not be far off the same i would have thought.........yes same thing
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    Drmatrix's Avatar
    Vorsprung Durch Technik
    Oct 2005
    London,UK
    160
    900rpm
    Audi A6 2.4 Quattro SE Cashmere Grey
    Audi Allroad 2.5 tdi (180) Quattro Limited Edition Metalic Silver
    Drmatrix's Avatar
    Oct 2005
    London,UK
    160
    goes higher when you first start the car then settles down when the engine has warmed up
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    Yeah, mine jumps to about 1200rpm on first starting and gradually drops down. If it stayed at 800-900rpm then I think it'd be ok but it tries to drop it down to about 300rpm at times and so nearly stalls.
    Cheers for your help peoples, much appreciated.
    Jan 2006
    North Notts UK
    11
    Different engine but when I got my 2.7T (tip) it had intermittent slightly irregular idle (revs dropping to 400) and lurched occasionally when creeping in 1st or reverse manouvering out of my drive and in car-parks. Took it back to the independent who supplied it and they cleaned the throttle body. That made no difference. Found a suggestion online that the aircon was the "cause". I've found that if I switch the aircon off when manouvering I no longer have the "problem".
    May have nothing to do with your 2.8 but worth a try if you haven't already.
    Tim
    2000W A6 2.7T Sport Quattro Tip Avant
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    Yeah I've heard a few likely causes, think i'm going to have to just experiment. I've given it a service, that seems to have helped a little. I've tried turning the air con off and it does help a little but problem is still noticeable. Think the throttle valve is most likely problem so at first possible chance I'm going to replace that rather than clean it. I've also heard that the coolant temperature sensor can create slight lurching problems if it has intermittent problems but not had any fault codes or anything to indicate that.
    Drmatrix's Avatar
    Oct 2005
    London,UK
    160
    Let us know what the results are dude
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    I've just tried a little test to help out. I've managed to get the engine to idle back at 850-900rpm without doing too much. The response when dropping back down to idle is still slightly iffy but it helps as a temporary repair.
    All I did was remove the air intake hose just after the MAF section (while engine was off, otherwise it cuts out) and then sprayed a mist of WD40 down the hose towards the idle control valve. Then connected it back up and started the engine as quickly as possible afterwards to suck the WD40 through the engine. It has definitely helped, which would indicate that it is the idle control valve at fault, probably just gummed up.
    It's a fair improvement on how it was but will still definitely need removing at some point for a proper clean out.
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    Have managed to stabilise the engine by replacing the throttle valve, couldn't believe how much oil there was in the old unit.
    Is there anyone out there with same idling problems that is looking to replace their throttle valve? I've managed to clean out the old unit, it is fully de-greased and cleaned up, the control side is pristine and should work a treat.
    50? Any takers?
    Mar 2007
    11
    No thanks, man...
    Is it fixed? - got a 2.8 myself
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    Yep, all fixed.
    The problem was a layer of gunk around the disc in the valve, so when it actually dropped down to idle then the disc completely shut off the intake.
    There is still a small shuddering that i believe is down the a dodgy oil breather hose, but still awaiting parts to replace that.
