Hi,
I've noticed the suspension compressor coming on quite a bit recently, the car goes up and down OK - well all the time really, but it doesn't list or drop when left overnight.
I've got the following fault showing up on Vagcom, I'm wondering three things,
1. How ofter do Allroad owners notice the compressor coming on?
2. Do other Allroad owners cars' keep adjusting themselves say when you take something heavy out of the boot, even with the Ignition switched off?
3. The sensor fault, does anybody know where this is, so I can check the wiring?
thanks
Adam
AG-COM Version: Release 607.3-UD
Control Module Part Number: 4Z7 907 553 A
Component and/or Version: - 2C1A1 X030
Software Coding: 25500
Work Shop Code: WSC 00847
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
thanks
Adam
1 Fault Found:
