how do i remove the lower part of the dash the bit below the steering wheel i can find the two lower bolts holding it on but cant find any other bolts anyone know where there situated?
as i remember you have to pul off the smal trim above the steering column, there are bolts behind there,
then there is a further bolt which you will find in the fuse box on the end of the dash,
