JMB RetrofitsAH Fabrications
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    loud clunk when i brake any ideas????
    i get a loud clunk from the drivers side wheel area when i break ive had the wheel off and everything looks ok any ideas i get it when i brake at high and low speeds even when the car rolls i get it
    200 Horses nice !!!
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    Dont forget the A6 is notorious for eating track rods etc.
    have them checked out as they could collapse. I remember having mine done on my last A6 , a month later I had a letter from Audi stating that they could collapse after high miles and to get them chcked. Bit late for me. I had them all done on both from wheels.
    Simon
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    i thought that was the problem because one was broken so i replaced it however im still getting the noise
    200 Horses nice !!!
    Jason's Avatar
    Mar 2005
    France
    186
    Ball joint,loose brake caliper,brake pads,Drive shaft,worn rubber bushes in the lower steering arm jobbies.
    Had a similar problem and it turned out to be a knacked shocker!!
    karl7900's Avatar
    Nov 2006
    1,402
    Your front bushes are probably worn by the sound of it. A kit is avialable which replaces 6 suspension links per side. I just got my '97 A6 2.4se sorted during the week there. The kit cost 250 from a local motor factor and fitting was 200. You can replace the links individually but you'll probably pick the wrong one like I did on my previous car, an A4 which has the same set up.
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    it turned out to be my brakes in the end the pads become loose in the callipers so clunk around
    200 Horses nice !!!
