Volks AutosJMB Retrofits
    Mar 2004
    29
    Air Con Belt Change
    Hi All,
    Can anyone tell me the easiest procedure top replace the Air Con Drive Belt on my 1998 A6 1.9Tdi please?
    Thanks in Advance
    Dav id
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    the air con belt is the accessory belt infront it is visible, you may need to remove the front clip and radiators to reach it effectively
    just a little a6
    Mar 2004
    29
    hi dummi,
    yes i know what one it is I was just wondering if the radiator had to be removed and also if there were any tensioners on the pulleys? also what is the easiest way to fit the belt remove the pulley or is there an easier way?
    thanks
    Dave
