Chris NottVolks Autos
    Jun 2006
    UK
    9
    Thumbs down Lowered Suspension A6 (C6 Chassis)
    How do...
    Any of you folks lowered an new shape A6? Just want to know your experiencies and if you can advise a local workshop who know what they are doing at a good price (around the Harrow, West london area)
    Looking to drop it by arounf 30-40mm and then shod some neat 18" rims.
    Jun 2006
    UK
    9
    Question Someone help me out!!
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    i'm droppin mine myself 40mm with gas shocks all round and on 20's!!! I'll let u know how i get on.
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    ABT A6 Avant 3.0 TDI S Line with AMD remap
    See this thread. I had a look at the ABT website, they appear to do kits that were used on this car.
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Dec 2004
    Bristol
    449
    is it a new new a6 or the 1997-2003 shape? Cos mine's now lowered, not too harder job but the only real problem was the bolt on the passenger side! right Bugger! 3 hours of beatin it with a lump hammer n it was out, tho my mate was a little heavy handed n bent the bolt hence 3 hours! we just decided, right it's stuck just f**kin whack it it'll come out!
    Twas quite straight forward, back = 1 bolt either side, undoo bottom of shock, drop arm n change spring!
    Front a little harder, in air wheel off, undo top strut bolt holding 2 top arms n remove balljoints, then undo bottom shock bolt so that bottom shock is hanging, then in engine bay undo the 3 17mm bolts (1 in bulkhead gutter), then pull the shock over the driveshaft n pull the unit out (held in by 1 circlip which just breaks off not important) then remove the arms n top cap with 13mm then if u got spring clamps compress spring n clamping the shock undo top bolt n swap over all the brakets n stuff n ur done. then just put it all back together.
    Jun 2006
    UK
    9
    Smile
    Thanks guys.
    Its a new shape A6 (2005)
    Brembo four pots went on last weekend.
    Just got some eibach springs and koni shocks to sort out the rock and roll.
    Straight from Ingolstat, the 19" new shape RS4 rims have arrivied.
    This weekend will be busy and then I'll take it down for a 4-wheel camber and quattor alignment to make sure everything is in check.
    Will post a couple pics after.
    Be well
