EM TuningMonster Motorsport
    Jun 2014
    17
    Help with some fault codes please.
    Hi I have had the following fault codes come up recently:
    01375
    00575
    Could anyone please tell me what they are and what they mean?
    Thank you.
    52 Reg Audi allroad 2.5 V6 quattro tdi
    Oct 2012
    102
    Not sure off the top of my head but if you google them with 'vcds' in the search too you'll get the pages on vcds website with explanations
    2001 A6 1.9tdi SE Avant
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    01375 - Valves for Engine Mounting: Stage 1
    01375 - Valves for Engine Mounting: Stage 1: Output won't Switch or Short to B+
    Possible Symptoms
    ## Electro-Hydraulic Engine Mounts permanently hard
    Possible Causes
    ## Valves for Engine Mounting faulty
    ## Wiring/Connectors from/to Valves for Engine Mounting faulty
    Possible Solutions
    ## Check Valves for Engine Mounting
    ## Check Wiring/Connectors from/to Valves for Engine Mounting
    Category: Fault Codes
    00575 - Intake Manifold Pressure: Control Limit Not Reached
    Possible Symptoms
    ## Sudden complete loss of Power
    ## Reduced Power
    Possible Causes
    ## Hoses incorrect connected, disconnected, blocked or leaking
    ## Pressure Unit for Turbo Charger defective
    ## Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    ## Check Hoses
    ## Check Pressure Unit for Turbo Charger
    ## Check Solenoid Valve for Boost Pressure Control (N75)
    ## Check Basic Setting > MVB 011
    00575 - Intake Manifold Pressure: Control Limit Exceeded
    Possible Symptoms
    ## Reduced Power
    ## Charge Pressure too High
    Possible Causes
    ## Turbo Charger defective
    Possible Solutions
    00575 - Intake Manifold Pressure: Control Difference
    Possible Symptoms
    ## Reduced Power
    Possible Causes
    ## In 1Z/AHU engines, stuck/rusted wastegate or actuator.
    Possible Solutions
    ## Check Hoses
    ## In 1Z/AHU engines, clean rust scale off wastegate/actuator to allow lever to move.
    Special Notes
    It is not uncommon for a TDI to set Implausible Signal Mass Air Flow Sensor (G70) faults and/or Boost Pressure, Intake Manifold Pressure faults when the engine performance is reduced due to excessive restrictions in the intake or exhaust systems. Restricted Catalytic Converters will directly affect turbocharger operation.
    Categories
    Main Page
    Diagnostic Procedures
    Common Procedures
    Fault Codes
    Retrofitting
    Immobilizer
    Meta
    Log in
    Live Phone Support
    Jun 2014
    17
    Wow thanks bez101, it looks like these faults have intermittently been present for a while, whilst looking through my service history before I took ownership I found these:
    Stored Engine electronics fault codes (27/08/09):
    00542 needle lift sensor G80 open circuit/short circuit to B+ sporadic.
    00575 intake manifold pressure, value above upper control limit.
    New sensor fitted part number 4z7941286c also injector number 3 replaced
    The needle lift sensor fault seems to pop up on a few services.
    Also found this one (25/10/10): 01375 Engine mounting valve-stage 1 output does not switch/short circuit to B+ intermittent.
    I'm really hoping the problem is the solenoid valve for Boost Pressure Control (N75) and not a defective turbo as the injector needle sensor is going to cost me a few quid as it is (different thread), it was replaced about 5 years ago, do they normally break so soon?
    The car has suddenly lost power once 2 years ago and once about a week ago, both times within a minute of starting and both times whilst trying to overtake (not ragging it as the engine was still cold) so I have ended up embarrassingly along side them.
    By the way thank you also the other mrnice!
  1. Need some help with a fault code please?
    By DaveA3-TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2011, 09:39
  2. I need some help with some fault codes please
    Last Post: 19th May 2011, 16:14
  3. Help with recorded fault code
    By Damian s in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2007, 18:33
  4. helps with some vag codes!!!!!
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th November 2005, 19:46
  5. Help with a part code please?
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2004, 16:48
