Volks AutosAH Fabrications
    imported_alex100a
    Squeaking from air con?
    Hi,
    Need a little advice. When I start my 2.8 V6 with the climate control switched on I get a fairly loud squeaking noise from under the bonnet which lasts anything up to about 5 seconds then stops until I restart the car.
    Any ideas what this might be? Its had a recent aux belt change so do not think its that.
    Alex [img]/ubbthreads/images/graemlins/confused.gif[/img]
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,596
    Re: Squeaking from air con?
    Still could be the Aux belt....may not have been tightened up enough. Or could even be another belt. Air con uses a decent amount of power so this could be putting strain on other belts. Check them all.
    Hopefully not, but it could also be the air pump on way out...
    Jul 2006
    Blackpool
    Hi !!!
    It looks like mine problem in my previous audi A6 '98-sometimes it comes on during the driving, but after switched it off or to eco mode squeaking metalic noise go off. I checked it in service and they told me that compressor shloud be replaced...
    mjhamilton's Avatar
    Broooom Brooom Brooom!!
    Jul 2003
    United Kingdom
    26
    Aircon Squeek
    Had the same issue for the past 3 years.. it is the electric fan that comes on when you start the aircon first thing.. mine makes a noise for about 20 seconds and then stops... if you put the system into econ mode it goes away cos the fan is stopped in the mode...
    1997/8 A6SE 2.4 30V Dark Green Metalic, had for 5 years now... old lady has only 30k miles..
