Badger5Monster Motorsport
    Mar 2006
    UK
    10
    Will A4 wheels fit the A6?
    Hi everyone. I've just bought an A6 saloon (1.9TDi, 2002). Great car. Really impressed so far.
    Will factory A4 5-spoke 17" "star" alloys fit straight on my car?
    What tyre size is preferred for the A4?
    Thanks.
    Mar 2006
    UK
    10
    Re: Will A4 wheels fit the A6?
    To answer my own question, my enquiries so far confirm they will.
    My question should have gone on to say "Which tyres will fit the A6?" (not A4!). I'm guessing that the rolling radius is the same on both cars?
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    both have pcd 112 , just check offset which will look something like et40 and you can use spacers to push it further out shouldn't be a problem. you can calculate rolling radius with alloy size + tyre wall, tyre wall is a percentage of tyre with, example 210mm width with 50 wall will have a 105mm wall. so add size of wheel 17" -> 432mm plus 2 x wall 105mm gives 642mm and compare to your standard wheel, around that size should be good enough
    anyone correct me if i'm wrong
