EM TuningVolks Autos
Results 1 to 20 of 20
Like Tree3Likes
  • 1 Post By B5 BIKER
  • 1 Post By ms1083
  • 1 Post By quattrojames
Thread: engine struggling for temp on a run,
    Apr 2014
    21
    hi, after searching the site I've found a few similar problems others have had, but not quite the same as mine,
    I've noticed that both my oil and water temps don't seem to move a lot, on a good motorway run I've seen 70 deg on both, but day to day they barely move, or at best register just above 60, heater seems to work but not boiling hot air at any point.
    I'm guessing a dead stat but just wanted to have it confirmed before I part with the cash lol
    could this have caused any issues engine wise as I've my suspicions its been like this for a while with the previous owner
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Try the coolant temp sensor first.
    I had the same symptoms and they were gone as soon as I replaced it. Had same issues on a b5 A4 also before
    Carlisle v6 tdi likes this.
    Apr 2014
    21
    cheers fella, I know in my heart of hearts its the right call, just wanted a second opinion as I said lol.
    now if only I could prise my wallet open lmao
    any idea on cost of genuine vag parts v's ebay specials??
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    If the oil temp is also low(less than70-80) then I would put money on the thermostat.
    Speak to adamss24.
    Lancaster
    1,787
    Personally I'd do the thermostat and temp sensor at the same time with genuine parts. Piece of mind and the cost is fairly low.
    To do: None yet.
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Quote Originally Posted by Carlisle v6 tdi View Post
    I wouldn't bother with the eBay cheapo ones to be honest.
    Bought mine from a dealer over here who does the febi ones nice and reasonable, and hasn't given me any trouble since.
    Not sure where the thermostat is located on the the v6, would be handy if anyone had a pic for future reference
    Dec 2010
    Wellington, Somerset
    106
    Assuming you are talking about the 2.5 v6 TDI. The thermostat is located behind the timing belt so to change it you have to take auxillary belt off & timing belts off. Bit of a job really, worth replacing along with waterpump at timing belt change.
    Temp sensor easy to replace & quite cheap - about £8. located on top of engine near the front, quite obvious.
    B5 BIKER likes this.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    When I did my 2.5 CTS it was £30 with a litre of coolant.
    As mentioned, thermostat is a front off job. Needs new timing gear etc so you're looking at typically £500 ish with genuine parts.
    Mar 2008
    Dorset
    13,856
    Here's the guide I wrote when I did it.
    2.5TDi Coolant Temperature Sensor (G62) Replacement Guide
    Apr 2014
    21
    Cheers James.
    I'll look into it.
    Was kinda hoping it would be on the top of the block somewhere but what to hoo it's gonna have to be done lol.
    Pretty sure cam belt and pump haven't long been done so saving cash already :0)
    Lancaster
    1,787
    Never even thought it would be a V6 TDI. Fingers crossed it's the sensor then!
    To do: None yet.
    Apr 2014
    21
    Not sure it would be the sensor as oil temp is low too, am guessing thermostat, explains why previous owner was happy to snap up a ropey trade in. Cash is tight atm so scraggs inline adaption is looking favourable, especially as mot is almost due and I doubt she will manage the emissions test with a cold lump.
    Purely a stop gap measure though before the purists jump on me lol, I figures an inline unit can be reverted to a straight through configuration when the time comes.
    YSN
    YSN's Avatar
    Sep 2013
    93
    I had a similar problem on my 1.9 Tdi and replaced the old sticky thermostat and the engine sees 90 degrees and stays there.
    Apr 2014
    21
    I've just had a suggestion that may work,
    Full rad flush and coolant change may unstick the stat, got to be worth a try, Damn sight easier than changing it, again only a temp measure.
    Jul 2011
    6
    I've got similar issues with an Allroad I've just bought and I am suspecting that the clutch on the viscous fan is seized meaning it is running at full rpm all the time. May be worth looking into that if the temp sensor doesn't fix it, before the expense of the thermostat change.
    Lancaster
    1,787
    Even if the fan is running all the time. The thermostat should close to stop over cooling.
    To do: None yet.
    myth's Avatar
    Dec 2012
    121
    You can test the viscous fan very easy: with the engine stopped, rotate the fan blades. If it moves ( you should feel a little friction), then it's all ok.
    If you plan to change the viscous fan, you are already halfway to change the thermostat. Also, BlackQuat is right. Even at full speed, your temp should be at 90.
    To test your thermostat: after starting the engine, drive until the temp needle starts moving. Open the hood and put your hand on the coolant hose circled in the picture. If it's warm/hot, then it's the thermostat.
    Apr 2014
    21
    Cheers for the advise guys, seems it's the dreaded thermostat after all. Can't afford to swap it out just at the minute unless I can aquire the cam tool then I'll do it myself. As a temp measure I have a (cringe) board between the rads which is helping vastly, almost getting to temp on a warm day lol.
    As soon as funds allow I'll be looking to complete the work and to also drop her oil and sort a bodged repair on the sump that is weeping a little.
    Oh and sort the rear tailgate light board which is leaking water in onto the fog light harness, half hearted attempt today was fruitless, going to rape a scrap car for newer parts to replace the corroded items on mine.
    Lancaster
    1,787
    I will lend you the cam locking tools if you need them.
    To do: None yet.
    Apr 2014
    21
    Fantastic I'd really appreciate that, it's the only thing stopping me doing the work myself really, I'll pm you.
    Cheers fella.
  1. What is the recomended engine oil for S3 please
    By daztenerife in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2013, 12:08
  2. engine spec for facelift A3? VVT?
    By s3tle in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2005, 12:38
  3. Engine Code for Polo GTi
    By chuffer in forum Volkswagen and other VAG
    Last Post: 12th October 2004, 12:09
  4. Engine modss for an A3 3.2 Quattro Sport w/DSG
    By imported_ilclifford in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th August 2004, 12:17
  5. Engine type for 2000 A4
    By imported_sashaberk in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th July 2004, 17:45
