Volks AutosAH Fabrications
Thread: Viscus fan
    Feb 2014
    33
    Viscus fan
    Hi,
    i mentioned before I had a funny whirring noise come from the engine, I'm pretty sure it's the viscus fan unit is stuck on or bearing is worn. The engine is a 1.9tdi, I haven't had a proper look but what size is the nut and will I need a viscus fan tool? Also are they reverse thread?
    iain
    myth's Avatar
    Dec 2012
    121
    They are not reverse thread and on my a6 it's a 32mm spanner.
    Feb 2014
    33
    Thanks for the reply, is it just one nut? I was
    Thinking of changing the coupling to
    Stop the noise? Or can you just change the bearings?
    Dec 2010
    Wellington, Somerset
    108
    yes 32mm. it is just 1 nut but you need 2 spanners 1 to hold it still whilst the other on the other side of the nut to loosen. There is not enough space for adjustable spanners but I got away with 1 large adjustable and 1 32mm standard spanner. Easy with the right tools
  1. Water pump/viscus fan!
    By HOTFUZZ007 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th February 2012, 16:48
  2. Fan Control Illumination
    By OMT in forum A8/S8 forum
    Last Post: 19th June 2004, 00:12
  3. Hello Audi fans!
    By Mithas_S6 in forum The Welcome Section
    Last Post: 28th April 2004, 20:07
  4. Cooling fans blow backwards?!
    By albany in forum Classic Audi Forum
    Last Post: 17th October 2003, 03:59
  5. Audi 90 CS Radiator fans quit
    By jlmata in forum Classic Audi Forum
    Last Post: 2nd June 2003, 15:19
