Chris NottJMB Retrofits
    CHRISTOPHÉ's Avatar
    Mar 2014
    Plymouth, Devon
    68
    Allroad suspension fault noob requiring help!
    Hi all I'm a long term VAG owner and have been hunting for something I fancy after selling my 4.2 A8 last year I have just bought this 2004 allroad tdi 180 with 124k on it it's got a LOT of engine history but I'm having problems with the suspension.
    It it sat on the bumpstops with the 1st level light flashing and the orange warning light is flashing and I'm not getting power to the compressor?
    I have done a few scans with a hand held but don't currently have access to full VCDS at the moment as I've got rid of laptop between cars it's not showing any faults. I have checked what fuses I can find but I'm not sure they are the right ones and also unsure of which relay is the one for the compressor.
    I have connected leads to the compressor and it runs from a slave battery but not through proper connector
    ANY help would be greatly appreciated
    thanks in advance Chris
    Jan 2014
    Aberdeen
    29
    You probably know this anyway, but best thing you can do is get it on VagCom, then you can test everything & see what the sensors are saying, otherwise it's all guesswork.
  1. Help a4 tdi avant suspension fault drivers rear control arm
    By samsam in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2011, 14:35
  2. a6 allroad suspension help
    By killin1 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th September 2011, 02:52
  3. vag com fault codes..... any help out there please?????
    By shufti in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th March 2007, 03:43
  4. 2001 Allroad Suspension fault
    By Adam C in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th January 2007, 17:54
  5. allroad suspension collapse
    By containersltd in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th January 2005, 07:56
