Sky InsuranceChris Nott
    Sep 2012
    Bristol
    MOTs Fog lights and fuses...
    2003 A6 C5 saloon.
    Hi all, I have just picked my car up from being MOT'd today and the only issue was the fog lights were u/s. The mechanic replaced fuse 36 (I think) and now the rear fog works, however the fronts still don't!
    Is there no requirement for front fogs to work for an MOT?
    Are the front fogs on the same fuse as the rear fogs?
    If so what else do I need to look at to get the front fogs working?
    Thanks in advance!
    Benyon
    Lancaster
    1,780
    Have you simply checked the bulbs?
    To do: None yet.
    Sep 2012
    Bristol
    I haven't, but I was assuming the bulb warning would have come on if it was bulbs, again assuming that works on the fog bulbs...?
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Front fogs not MOT failure. only must have O/S/R or Central rear.
    Sep 2012
    Bristol
    Ok that's good. Do you know if front and rear foods are on the same fuse on a 2003 1.9tdi?
  1. 1 fog light and then two or even none.
    By ScottD3 in forum General Automotive Chat
    Last Post: 9th March 2012, 14:53
  2. Fog light and main beam bulbs... Higher wattage??
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2011, 21:05
  3. esp, abs light and fuse..
    By gibo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2008, 10:01
