EM TuningAH Fabrications
Thread: 19" Alloys
    HNH5's Avatar
    Jan 2006
    Newcastle Upon Tyne, England
    42
    19\" Alloys
    Has anyone fitted 19" alloys to an A6 1.8T? I'm just wanting to make sure there's not going to be any clearance problems before I buy them.
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    Re: 19\" Alloys
    Yeah mate i'm fitting 20's to mine, Just make sure the offset is et35 (or can be made to et 35 with spacers)
    And that the wheel is not any wider than 8.5 inches on the front, cos any wider and it hits the bloody strut which they made too close to the wheel!
    You may be able to get 9 inch wide rims on the front at a squeeze but with 20's 8.5" wide on the front is the max for standard arches.
    I've found this out having bought a set of 9.5x20 wheels! too wide!
    they just won't go on a normal a6, but the will go on rs4's and rs6's
    Hope this helps
    HNH5's Avatar
    Jan 2006
    42
    Re: 19\" Alloys
    Cheers. Yeh, the offset is et35 and they're only 8" wide so looks like i'm ok. Thanks again
    Dec 2004
    Bristol
    449
    Re: 19\" Alloys
    yeah that will be fine, i had 8.5x18's on mine, now going for 8.5x20's - 1850!
