Monster MotorsportVolks Autos
    Feb 2006
    wales
    A6 Passenger side airbag disablement????
    Hi there, new to this site but would like some info. if at all possible.
    I have a 1998 A6 Avant 2.5 Tdi and due to a recent addition to the family would like to be able to disable the front pass' side airbag.
    There is no keyswitch in the glove box or anywhere else for that matter, Audi want 300 to undertake the work.
    Audi said that they need to fit a keyswitch and loom as there isn't any on the car(fair enough) but what else is needed???
    Is it just the case that it's a simple two wire input into the 'airbag ecu'(if there is such a thing) or not??
    Would appreciate any comments/experience if possible please
    Thanks for your time
    Jun 2003
    Hythe, Kent
    1,180
    Re: A6 Passenger side airbag disablement????
    This thread may help you a little.
    Kev.
    Feb 2006
    wales
    OK. Though I'm still not sure what is involved/get for your 300? Is it just a loom and keyswitch or much more, guess I'll have to bite the bullet......
    Jun 2003
    Hythe, Kent
    1,180
    Well, I'd imagine you'd get the loom, key switch, new center light cover which would incorporate the warning light and the rest is made up of labour to fit.
    Assuming Audi are right and it can be retrofitted, (as can be seen in the above thread, can be retrofitted to a B6 but not a B7), a cheaper option though may be deactivation with VAG.com?
    Hopefully someone will know...
    Kev.
