Volks AutosMonster Motorsport
Results 1 to 9 of 9
    72
    RNS-E potentially draining battery?
    When i bought my allroad the Nav DVD was missing. So the dealer gave me a disc from a 2007 A4 RNS-E. I have noticed that the compass/road name is not displayed in the DIS like on other C5 and also the unit hisses a lot when i get in the car and turn off the ignition.
    Is it possible that the 2007 A4 disc has altered some sort of coding and the unit isn't shutting down and not coded properly for the car and this is what's draining the battery?
    2,179
    It does sound like the can-bus wires are not connected or some how been disconnected. Do you know if the RNS-E was retrofitted or factory fit?
    72
    Factory fitted.
    2,179
    you need vcds to confirm, but if you are not getting information on the DIS and the radio is not switching off with the ignition then there is a can-bus problem.
    72
    Just for clarification it does show the navigation parts but only when in route guidance mode, other C5's i've seen show the road name and compass as an option on the DIS even when not using the route guidance at that time.
    Lancaster
    1,788
    That's an option within the RNSE. You can enable it.
    To do: None yet.
    72
    Quote Originally Posted by BlackQuat View Post
    Ah okay! Not that it will help the drain, but how do you enable it? Is it in the engineering menu?
    Lancaster
    1,788
    Just in the settings on the RNSE it's self.
    To do: None yet.
    Jan 2014
    Aberdeen
    30
    The cooling fans on my sat nav plus run for a time after shut down, you don't hear them when the engine is running but do once you turn off the engine. They only run for a short time, a minute or so max I would guess.
  1. Car a aftermarket HU and amp with no ignition off drain battery??
    By mjsummer in forum In-Car Entertainment
    Last Post: 21st December 2011, 17:23
  2. Alarm draining battery?
    By Foxmeister in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th August 2011, 23:18
  3. Water pump running on after ignition off & draining battery - help please
    By The Doctor in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2011, 08:00
  4. Tails lights turn on unexpectedly....draining battery
    By ward0166 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2008, 16:29
  5. few issues... draining battery, lumpy idleand sounds like a tractor
    By hannakournikova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2008, 10:27
