AH FabricationsChris Nott
    d-9
    Feb 2014
    16
    2.7T oil driven cambelt damper
    My A6 is currently in for its cambelt, and I've had a call from the service manager telling me that they also need to replace the 'oil driven cambelt damper', which is apparently part of the oil pump, for only £120+vat. Has anyone who's done a cambelt on a v6 seen such a thing? I cant see it on the parts diagram!
    d-9
    Feb 2014
    16
    So as an update I went to see the audi service desk today (after they'd promised to call me back at 9.30 and didnt), it turns out they were talking about the cambelt tensioner damper, which isnt part of the normal cambelt service price - seems pretty shocking as its cricual for cambelt tension.
    Apart from not calling back I'm really impressed with the service from Parklands Audi in Cheltenham, they had got on and sorted the car, gave me a really good rate on the parts and labour, and the whole bill was only slightly terrifying.
    All-rod's Avatar
    Sep 2011
    Essex
    27
    Glad to hear you car sorted now. It is not unusual for older cars needing tensioner or two replaced when changing belts. Good thing if they check all thoroughly and spot when one its on its last legs rather than it failing later while driving. On my Tdi ac belt tensioner failed less than 5k miles after cambelt change, good thing it did not do any damage.
    Stock 02 Allroad, AKE, Tip Auto.
    d-9
    Feb 2014
    16
    Agree it's sensible to replace, I'm shocked that Audi wouldn't replace it as part of the cambelt service normally.
  1. Cambelt or chain driven?
    By tanz1978 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 18th July 2011, 08:56
  2. Cambelt Tensioner Damper - Heads Up
    By Piester in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2011, 21:47
  3. Oil appearing after Cambelt change
    By phil_w in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd August 2010, 10:48
  4. Febi cambelt kit and damper
    By abdus in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2008, 22:56
  5. 058 109 479 B damper cambelt
    By Bellic in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2007, 13:32
