AH FabricationsVolks Autos
    Mar 2012
    244
    HID Adjustment Error
    Having fitted the new bulbs thought I would align them. WRONG!
    It all started well with VCDS (Reg Copy) and Module 55
    Adjustment 04 Group 01 Good
    Set up headlights
    Then GO
    or rather NOT
    Now lit up ERROR in Group 1 and 2
    Tried Adaption back to default and re-code which all worked
    Motors run all seems to work but errors still.
    Headlamps not adjusted 01539 error Makes sense as I never got to 002 GO.
    Any thoughts?
    Mar 2012
    244
    Might drop this on the VCDS forum...
    Jan 2014
    Aberdeen
    30
    There is a very specific procedure on RossTech, and I found if you didn't follow it exactly it error'ed like this! I had to go back to the beginning and follow it precisely. Though on checking it looks like you followed this procedure...so i'm probably not helping.
    http://wiki.ross-tech.com/wiki/index...(Dynamic_Light)
    Mar 2012
    244
    Appreciated. Think I did it to the letter. Looks like the motor is running but not cycling up down. Headlamp out then.
  1. HID self leveling error
    By gixerson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2012, 12:32
  2. my 3rd party hids now say right head light dipper error
    By subaru swift in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st August 2011, 17:06
  3. Bulb error after HID attempt
    By Xmay4444 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th August 2009, 21:15
  4. CD-Error 2 problem???
    By Jack829 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2003, 21:30
  5. Errors!
    By A4Steve in forum General Chat
    Last Post: 7th February 2003, 10:17
