brimley mill
Hello all,
Well here I am again asking for advice from all you much more knowledgeable than I....
I have recently bought a 2003 2.7T auto allroad with 46k with ASH, the following problems have now surfaced and would appreciate your guidance and advice.
1) When I start from cold in the morning and select reverse or drive, most times the box will select with a jerk, and interestingly the gear selection characters on the dash are blocked with a red block and the characters are black - normally red.
Also when in drive the car will only pull away in what feels like 3rd gear, and when doing this mode, I don't get manual/tiptronic functions regardless of gear lever position or the buttons on steering wheel.
If I turn the engine on and off, on most occasions it will revert to normal function but this might take a couple of times.....
2) The front end shimmies at around 40-45 mph - (it feels like my BMW 540 use to) and also when at say 70-80-90 mph the steering wobbles almost as if there's a bulge in a tyre or are out of balance (tyres are new and the rims are fine)
3) Rear tie bars/control arms (uppers) are seized and eccentric bolts are damaged. Bolts are no problem..... the arms are.
I have tried Eurocarparts, Unipart, GSK etc and they are not listed..... does any one know where I can get these competively in say Europe or even the USA
I am leaning towards pushing the bushes out and using a Powerflex polyurethane type bush making this much more durable. Has anyone done this and if so, knows where to get these bushes ???
I am technical and capable with access to a 4 post ramp so doing these jobs isn't an issue, but just would like to know where and what the pitfalls are and guidance as to how to go about these.
Many thanks for your time.
Kind Regards
Jonathan
Kind Regards
Jonathan
