Chris NottMonster Motorsport
Thread: coolant warning
    May 2013
    20
    coolant warning
    So I fitted new brakes today (discs & pads) so the brake warning light has gone off.
    And guess wot, another has appeared same day!
    Coolant warning light.
    Coolant is full, no issues with over heat.
    So I presume its the bottle sensor.
    Can I buy the sensor or is it a new bottle?
    Part nos pls?
    Thanks.
    Mar 2012
    221
    Quote Originally Posted by 964russ View Post
    Part nos pls?
    Thanks.
    The pins on the wear indicator are pathetic...and the clip that holds the two parts together ain't much better.
    I wrapped a slip of tin foil in to each of the female stakes on mine as it went off with every puddle.
    Then a wrap of tape to ensure both halves of the connector are tight up.
    Gentle scrape of the metal pins inside the Coolant reservoir with a screw driver usually helps.
    If not pull it out and soak in scale remover for 5 mins (no more)
    Otherwise...6 cylinders should be 8E0121403D
  1. coolant warning on start up
    By silver75 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2006, 13:21
  2. coolant warning light
    By milie in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2005, 14:48
  3. Coolant Warning
    By kash0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd June 2005, 22:50
  4. coolant warning light and buzzer.
    By imported_55spike55 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th September 2004, 19:38
  5. S3 Coolant warning
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 21:02
