EM TuningSky Insurance
Results 1 to 16 of 16
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    Couple questions 2.5tdi/1.9tdi Quattro avant mpg and towing capability
    Hi guys, I'm tempted to swap out my A4 for something a little more economical and more practical. So far the a6 tdi Quattro avant seems to tick the boxes.
    How do both the 1.9tdi and 2.5 tdi fair when it comes to mpg when combined with the extra weight of the avant and quattro floor pan? Is the extra mpg from the 1.9tdi worth the loss in performance?
    I'm thinking that I may one day want to tow my Nissan when going to track days etc, how do the above specs fair as a tow cars? I've heard somewhere they are rated at nearly two tonnes, is this true?
    Many thanks in advance
    Jul 2007
    London
    3,213
    A6 tdi quattro was not available with the 1.9Tdi engine, only with 2.5 tdi engine...
    FOR SALE:
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    I've never seen an A6 C5 1.9 Q! Only 2.5TDI. Might be wrong though. If you want to tow, then the torque of the V6 is you only option.
    Dec 2011
    Somerset
    474
    A6 2.5 V6 tdi Quattro it is mate to tow a slow Datsun
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    I'd try to get a manual gearbox though, my personal preference.
    Regarding MPG, the 1.9 will be better, but I get an average of 46-50 mpg out of my 2.5, (FWD though!) A decent map improves it no end.
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    Cheers guys, didn't realise that the 1.9 wasn't available as a Quattro :o I'm guessing the Quattro would have a higher tow rating? If the v6 would get mid to high 40's on a run I'd be happy
    Quote Originally Posted by Gazwould View Post
    Ha ha small world mate. I am indeed thinking about dragging the slow Datsun to track days etc incase I break it again :D
    Dec 2011
    Somerset
    474
    What did you do to it ?
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    The nissan, blew the head gasket in spectacular fassion and warped the head so badly I had to buy a new engine
    I like the idea of having a daily driver which is both better on fuel than my 1.8t a4 and capible of towing the nissan. I'd imagine it would need a 2tonne capacity or there abouts.
    myth's Avatar
    Dec 2012
    117
    If you want to save money over time, the 1.9 is the best option.
    Just in case you need to replace the thermostat on the v6, you need to (almost) remove the timing belt. If you have problems with almost everything on the engine, you need to take of the front end on the v6. On 1.9 it's far easier to keep it maintained.
    I personally like the v6 for better performance, better sound and the mileage between the two engines are almost identical.
    Dec 2011
    Somerset
    474
    That was a while ago, I do look in from time to time.
    I'm thinking I over spent on mine and won't add up the invoices, but yours now ....
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    Quote Originally Posted by myth View Post
    Thanks for the input I'm thinking the 1.9tdi is out of the question now seeing as they don't do it with the quattro platform It's a good engine and seems to go on forever returning great mpg in my friends cars so it's a shame I do like the idea of the greater torque of the v6 though.
    Thankfully I have a fully trained friendly mechanic who is always after extra work so maintenance isn't too bad, I got the cambelt swapped for less than £100 on my 1.8t including good parts as he owed me a favor :D
    No comment :D I've spent far more than it's now worth that's for sure....
    Jul 2007
    London
    3,213
    I would not dissmiss the 1.9Tdi just because it's FWD, it's more than capable, however, i would choose the v6 for every other reason ! I have a gttdi pd 130 golf mapped to 170Bhp, a old b5 1.9 tdi quattro sport with a few bits and bobs, a b6 s4 quattro mapped to 370-380 Bhp and a few more cars in between, i choose to drive the v6 diesels daily ...
    FOR SALE:
    Oct 2009
    Preston
    88
    I tow Alfa race cars regularly with 2.5 Quattro Avant and its great - no problem with anything - would always choose manual box though, but don't think you'll see mid 40's mpg maybe high 30's normally and high 20's, maybe 30 when towing.
    Its great when you drop the trailer off and still have 3 hours to do to get home, the first hour on reasonable A roads with sometimes but not always, no traffic and no trailer
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    40's on a run would be acceptable without a trailer Only reason I would dismiss the 1.9tdi is because it sounds like it's only available in the 2wd option which I would imagine would drop the tow rating as it does with the b5 A4...
    May 2013
    20
    A6 1.9tdi can tow 1800kg.
    Thats enough for a trailer and a car.
    Jul 2007
    London
    3,213
    Quote Originally Posted by 964russ View Post
    I would say that's not the case with the 1.9 tdi, it's not about if it can tow but how it can tow ! A large, with plenty torque engine will make progress rather easy and will put the power on the road nicely, it will also be more stable with 4 wheel drive/braking and will be that much easier to pull the outfit up a slight incline... Also larger engines tend to have lower gears so they can cope with towing much better...
    To get the same load pulled with the smaller engine you need to slip the clutch as they do produce their max. torque much, much higher up the rev range. That's one of the reasons why diesel engines make good tow cars compared with petrol engines.
    FOR SALE:
  1. 1.8T Quattro Avant MPG
    By Mazi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th November 2013, 00:37
  2. 1.9tdi Quattro avant!
    By Chriscooke in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd August 2013, 09:19
  3. Value my car - 1.9tdi quattro avant
    By munchkincoupe in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th February 2013, 13:24
  4. New shocks for A6 2.5TDI quattro avant
    By fjtwelve in forum Handling
    Last Post: 10th March 2012, 22:22
  5. Replacing engine mountings on '96 A4 1.9tdi Quattro Avant
    By chuffy in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2006, 15:26
