Sky InsuranceVolks Autos
    Dec 2011
    22
    Airbag warning light
    It came on after I took the passenger seat out, any ideas how to clear it as the seat is now back in and reconnected?
    kite's Avatar
    Oct 2007
    East Berks
    675
    You will need diagnostic kit. VCDS.
    You could try a battery disconnect and see see if it clears. Have your radio code handy.
    A4 (b6) 2.5 TDi QS Saloon.
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Yeah check the vcds map to see if anyone local. Not sure if battery disconnect will work as ive never tried that but def worth a shot.
    Audi S3 8P3 / REVO Stage 1 / REVO Ceramic Intake / NGK Iridium Spark Plugs / LOBA HPFP / Philips Diamond Vision 5000k Fog Light Bulbs /
    KW V3 Coilovers / Team HEKO Wind Deflectors / Bridgestone Potenza S001 92Y Tyres / Complete LED Bulb Conversion (int' + ext') / Ashtray Delete /
    TTS Engine Cover / Alpine 928r Multimedia Station (8in screen) with integrated Bluetooth, Sat Nav etc / Ross-Tech VCDS Owner.
  1. Airbag warning light
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2007, 18:05
  2. A4 airbag warning light
    By PembsA4TDi in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th December 2006, 09:46
  3. Airbag Warning Light
    By reynot01 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th February 2005, 14:20
  4. Airbag Warning Light
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st November 2004, 23:01
  5. airbag warning light stays on
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 23:32
