Volks AutosJMB Retrofits
Like Tree1Likes
  • 1 Post By quattrojames
Thread: Avant Boot Problem
    May 2013
    17
    Avant Boot Problem
    Am Currently having problems with my boot - sometimes it wont shut! When this happens it does not seem to be any special trick to get it to work again, but when it does, it works properly for ages
    Anyone out there got any ideas as to how to sort? Cheers
    Jun 2013
    Sandviken, Sweden
    19
    I'm guessing the mechanism needs cleaning and a bit of lubrication. Can be the lock itself, handle or linkage between. Or all of it.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Boot solenoid probably?
    May 2013
    17
    Have had the boot lid in bits this morning, it seems there are two rods connected. The one that goes toward the passenger side is what is causing the problem. Does anyone know what this is and what it does? The boot is now working without any problems!
    Mar 2008
    Dorset
    13,856
    That rod goes towards the solenoid, the solenoid is what remotely unlocks the lock. Maybe you've freed it up, hopefully it won't cause you problems again. Certainly in A4's the solenoid failure isn't unusual.
    6833jon likes this.
    Mar 2011
    61
    My old b5 had a similar issue - it seemed to help when I lubed the moving parts in the tailgate assembly.
  1. Avant boot lock problem
    By Paul @ Unit in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2011, 19:53
  2. Avant Boot Sensor Problems
    By scammo in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd March 2011, 21:18
  3. Allroad/A6 Avant boot tray
    By gav210770 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd December 2005, 20:07
  4. AVANT BOOT TRIM
    By ivor1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th November 2004, 12:42
  5. S3 Boot problem...help needed...
    By Austin in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2004, 23:39
