JMB RetrofitsVolks Autos
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    boost question about n75 and actuators
    So, Basically, i had a set of KO4's put on my 2.7t and had it mapped with boost set to 1.4 bar..... a year later and the turbos failed, got them replaced under warranty but now with new turbos on i only hit around 1 - 1.1 bar with a bit of a spike to 1.2-1.3 in 6th gear only but then settles back to 1.1, never drops off or anything like that, so dont think iv got any leaks, could it be the actuators pre-load is set differently? or would this not make any difference due to boost be controlled via N75?
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    so, i have managed to adjust my actuators and i have also done the spring trick, ie fitting a spring to the actuator to hold it closed for longer, I now hit 1.4 bar, but still can not hold it, it drops back off to 1.1 and then holds all the way up the rpm range,
    any other ideas?? N75? dont belive i have a boost leak as then i would drop below 1.1.......
    please please help
    Jan 2014
    Aberdeen
    30
    Hi
    As a first step you should be able to check requested boost and actual delivered boost in VAGCOM, then you'll see if it is the computer doing this or if you need to look for pin hole leaks in vacuum lines etc.
    Andy.
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    yeah if i had vagcom lol was thinking about paying some one at the end of the month to plug in....
  1. N249 bypass.. questions about N112 and SAI, help please (welly lol)
    By coyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2011, 00:05
  2. Questions about bulbs and suspension
    By PregnantNproud in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2010, 21:47
  3. Another question about lowering and wheels....sorry!
    By dirk technic in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th April 2009, 12:22
  4. question about fmic and turbo
    By mattm in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2007, 22:44
