EM TuningAH Fabrications
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    Can some one help with a make shift tool for strut mounts
    Basically ever since i fitted my coilovers, every month or so im having to take the rear struts out and tighten up the nut, i think its because i have never had a good enough tool to tighten it right up. Iv been using a socket, with a hole on the side to put a bar in for leverage and then the only thing i can use to hold the strut still is a pair of long nose pliers. I know there is a proper tool from audi, but will only use once. Any other ideas???
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    It should be tight enough using a pair of long nose mole grips and turning the strut part with an Allen key. If the nut is coming loose, I suggest you get a new nut, it should have the nylon but that makes hard to undo, or try and stick some thread lock on it. The proper tool is a socket with a hole in it like yours, but there's a nut shape on the top so you can use a ring/open end spanner to hold it still whilst doing up the Allen key part.
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    mine is slightly different as i dont have the allen key bit,i have a square bit on top of the strut
  1. CAN SOME ONE HELP WITH THESE WHEELS PLEASE
    By big_ross67 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2011, 11:30
  2. Replies: 3
    Last Post: 22nd January 2011, 14:00
  3. Can some one please help?
    By TURBOTRONICS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st August 2010, 21:55
  4. HI Guys- im new. Can any one help with some questions i have.
    By a3dee in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th June 2010, 22:15
  5. Can some one help me please?
    By Ash B in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2008, 15:41
